How to set Mozilla Thunderbird?
Hello friends,
How to go about setting up Mozilla Thunderbird as email client to receive and send mails from Gmail and Yahoo?
Can i combine two account in one?
Hello friends,
Mozilla Thunderbird does not support webmail, but if you want to use webmail like Yahoo or Gmail, You need to install an add-on that imitates a POP server. Sadly, you need to have a paid-for Yahoo! Mail so you can set it up with Thunderbird, otherwise it won’t work (But then there is this other option to use Yahoo! Mail for free on a desktop client such as Thunderbird, You can install the YPOPs! Client).If you have a paid for Yahoo! Account or have successfully installed the YPOPs client – You can go ahead and set up Yahoo mail in Thunderbird. Here is a useful link on a step by step guide on setting up your Yahoo! Mail:
As for Gmail, Gmail supports a free POP, SMTP and IMAP server on all its webmail accounts—so you can definitely set up your Gmail for free. Here is a link on a step-by-step walkthrough in setting up a Gmail account in Thunderbird:
Yes, you can combine your two accounts in one – but you need to have the latest version Mozilla Thunderbird 3, it combines individual Inbox and allows you to manage all your emails in one spot
Hey Jaxon santiago!
If you want to configure your Mozilla Thunderbird as email client then you have to follow these steps.
1. Open Mozilla Thunderbird.
2. Click on Tools button on the upper toolbar and select Account Settings.
3. Click on email Account and then press the Next Button.
4. Now enter your g mail id and your name.
5. Now you have to select IMAP or POP according to your incoming server. Remember for POP your incoming server is pop.secureserver.net and for IMAP it is imap.secureserver.net. After selecting it, click on next button.
6. Now you have to enter the outgoing User Name and Incoming Username and select Next.
7. Enter the name of your choice and then click next button.
8. Click on finish button after the verification of your account.
9. Now you have to select the Outgoing server from the list in Account settings.
10. Change the port to 80 and type smtpout.secureserver.net in server name
11. When you try to send email for the first time. The Thunderbird will ask for your username and password. Give the Username and password and click ok to proceed.
Thanks
Wow, Tunacao_Caaron1. Thanks for your detailed steps. I chose POP for my incoming server, entered my outgoing and incoming username then verified my account. I changed the port to 80 as what you'd said and type smtpout.secureserver.net. Now my Mozilla thunderbird set-up is finished.
Thanks
Mozilla Thunderbird is a free email software on which it is included when you download Mozilla Firefox as your default browser,
It is very easy to set this free email software, first you need to change your account settings, once you done it just open the Mozilla Thunderbird look for Tools then Account Setting,and then just follow the instructions of the wizard.Just fill up the forms and give all the information needed to make a new account for the Mozilla Thunderbird its kind like your making a yahoo mail, you need to give your name and other personal details in order to put up an email account for the Mozilla Thunderbird.
Yes you can do that combining your account for the Mozilla Thunderbird, for example if your using Google, you have to set up the out going server information, for Gmail you need to enter smtp.gmail.com and you change your port setting to 955, after you done it just click ok and your ready to use your Mozilla Thunderbird account.
