How to set my picture in Microsoft word?
Both Microsoft Word Processor 2007 and 2010 have surprisingly advanced on photo editing. It includes multiple tools to change a picture’s color settings. Rather than decreasing or increasing the picture’s saturation or opacity or make it transparent. You can do it using the "Washout" setting on the toolbar. Once you open the tab that contains picture editing tools.
Washing out a picture makes it look very pale by keeping its original colors but transforming them to much lighter shades. So that the entire picture or image looks closer to white than it does full color. You can do this function by clicking on the picture once. Then click the "Format" tab on the toolbar. Select the "Color" button on the Ribbon, and in the "Adjust" section on the left end of the Ribbon. A drop down will appear. Then select the "Washout" option on the drop-down menu, under the heading "Recolor”.
To set a wash out picture in MS word 2007 follow the steps below;
Steps below is how to change color mode of original image into washout/lighter simply in MS Word.
Image as example only (to see the difference from original to washout)
Applies to Microsoft Office 2007.
Applies to Microsoft Office 2002 & 2003.
Please be advised to use Print Lay out View and not in Web Lay out view because the watermark does not appear in the latter.
In Microsoft word there is no special method to set pictures. But you can see a folder "Picture".Here you can save your picture through video mobile phone memory or with MP3. You can open a new file. You would write your file on a new open Microsoft page.
Click on main menu "Insert" after it click on sub-menu "Picture". Many options are waiting for you.
Options are:
From scanner or camera.
You only took picture from your "Picture"folder and put your file name in the "Insert Picture" dialog box and click on Insert,you will too find a little dialog box "Picture"by which you can edit your picture and you will able to set your picture surely.
