How to set up Netscape Navigator POP3 client?
Do you have any thoughts on how to set up Netscape Navigator POP3 client? I really have no idea so please help me. Thanks!
Without any hesitation, follow the process below. Though it seems like so long but it’s so easy and make you resolved.
Here I discuss the setup for Netscape Navigator POP3 client 6. Because you don't say about your version.
1. Open Netscape Mail from Start then click Programs, then Netscape 6 and then Mail.
2. In the mail window, open edit button and then Mail/News Account Settings.
3. In the Account settings, make a click and select Outgoing Server (SMTP).
4. Now enter pop3.ChangeIP.com in the server name box.
5. Click user name and password check box and after that select never and click OK.
6. You can click "New Account" and finish the Wizard first, and then come back and edit the Outgoing Server Settings.
7. When you come back to local folder window, click on Create a new account" link under Accounts, it activate the new wizard.
8. Choose the type of account you want. Now click next.
9. In the first box (Identity) write your name, and put an email address on the second box. Click next.
10. Now choose POP and put pop3.ChangeIP.com in the server name box. Click next.
11. Now put your email address again (same one) in present wizard.
12. On Account Name section, select a name for this account (for example, your email address), and click Next.
13. Now verify your account details, and click on finish button.
Now your setup is perfectly complete.
