How to set pin code for Pendrive
Hi Techyv,
I need to Protect my Pendrive by setting a pin code, is there any software for that. Please advice on how to set pin code for Pendrive, Waiting to hear from expert suggestion.
Thanks,
Zachary Cashh
Hi Techyv,
Thanks,
Zachary Cashh
Hello Zachary,
The answer to your question on if there is a software to protect your pen drive is yes. You can securely protect your pen drive with the USBSAFEGAURD software. This software enables you to password your pen drive and it uses an AES 256 bit encryption.
You can download and use USBSAFEGUARD for free if the maximum size of your pen drive is 2G. But you will have to pay if your pen drive has a bigger size.
I do hope this helps.
Regards.
Hello Zachary Cashh,
Yes, there are a lots of software to password protect your Pendrive. But most of them are paid. If you don’t want to spend a penny, then go for USB security. This is one of the and is completely free. It protect not only pendrives, but also memory stick, flash drive, thumb drive and external drive. No need to download as it is a kind of portable software. It protects user’s pendrives with complete and strong security.
See the attached file below
Thank you,
Wagner Desantiago
