casey cock
30 points
Posted on - 08/30/2012
I have windows 7 installed and was hoping if someone will tell if it is possible to set pop up reminder for various things in windows 7? If there is any other way, also tell me. Any kind of help would be appreciated.
How to set pop up reminder for Windows 7?
Hello.
The following are the steps to be followed.
1. Go to start menu, type "tasks" in the search field.
2. after Windows 7 searches the results, click on Schedule tasks as shown in the figure below.
3. once the Task Scheduler opens, select the Action menu, and choose "Create Basic Task"
4. Type what ever you want to set as your reminder, and then click Next.
5. In The next screen select your choice: For one-time notification, choose "One Time"; for repeats, choose "Daily" more than once a week select "Weekly" several times per month select "Monthly"
6.Then click the "Next" button, and select date and time for the notification.
7. Click Next, and select "Display a message":so that Windows 7 lets you type some text that will show up in your on-screen alert message
9. And here is the example image of the remainder.
Thank you.
I hear your concern regarding this issue, try the “Task Scheduler” of your windows 7 operating system.
1. Click “Start” button and type in the search field. “Task Scheduler” read and observe all the details that is needed to be perform.
But if it is not the one you are looking for I am giving you some option.
a. Open your browser and copy the link below in your address bar:
https://en.softonic.com/s/pop-up-calendar-reminder/windows-7
Find Daymate and download it, it is a pop up reminder that is compatible to windows 7 Operating system.
I hope this will be a great help to you.
