How to set reminder system tray schedule in PC
How to set reminder system tray schedule in my PC with Windows XP. Do I need to install any small software for that?
Wassup Green Scott, I guess I can be able to help you with the question, what you need to do in this case is download a software to help you with that. The best software to use to perform that task is one such as 'Personal reminder'
To get this software, open the browser and navigate to;
http://download.cnet.com/Personal-Reminder/3000-2074_4-10546393.html and download.
Follow the prompts after download when installing the software to be able to install it as required. The personal reminder handles daily, weekly, monthly, quarterly and yearly reminders.
Once installed, you can set the reminders you require to alert you of events.
I hope this solves your query.
Notifications
