How to set remote web camera software in office?
I run a business firm where I want to put some remote camera. So I want to know details about this. Please kindly tell me how I can set remote webcam & remote web camera software in my office or home pc to monitor my business.
Answered By 0 points N/A #163780
Tyr this solution, but first you must have a  program called orb 2.0 (you can go to https://twitter.com/namecheap – it takes 1-2 minutes to do, the program is very automated) this program supports multiple webcams (it also supports audio, videos, images as well as documents).  This will also auto detect the device and its connection speed in real time transcode the stream to be compatible, it offers the best quality for available resources, and it is easy to setup.
Once it is set up, head to https://www.noip.com/support/knowledgebase/how-to-setup-a-webcam-and-access-it-from-anywhere/, just log in and you will be able to view the webcam and also any other files you added to the share list.  It can support any device that can load the web page, based on the header or any other information provided by the device, it will automatically transcode the video, audio or anything else to work with the device.  You can manually select the format you want to view the video if ever there is an unknown device used.
