How to set a ring back tone nokia?
Hi techyv,
How to set a ring back tone Nokia? My Nokia mobile phone device model was Nokia ​n70, can you give me some instruction on the step by step process of subscribing or setting up a ring back tone for my mobile phone device? Please give some advice.
Hoping for your help and kind consideration.
Answered By 0 points N/A #174287
Dear user,
It is very simple to set a ring back tone in your phone Nokia n7.
Dear first download your desired tone in your phone from internet or from your pc. When you will download your desired tone into your phone then simply go to the tone destination. Means if you have saved this tone in E: so go to E: and click on your tone options, a list will appear having many options. In this list you have to choose "forward" or "send to" then a new list will open, you have to choose "to user profile" from this. And then close all these.
Go to menu click on settings then go to user profiles here go to the tone settings and select the tone you have forwarded to these profiles.
Your tone will be turned on.
Hope this will help you.
Regards
