hewitt
Posted on - 10/31/2011
I have a rule set up on my Outlook 2007 to forward incoming mails from a distribution account to my personal email account. However, I noticed that digitally signed incoming emails are not automatically forwarded. I suspected, may be the digital signature which requires a password. Is it possible to set up a rule removing the digital signature?
How to set up rule in removing the signature in Outlook 2007?
All you have to do is right click on their email, click the box that states who the email is coming from and that you desire those emails, digital or not, then select the folder where you want to place them and the rule should work.. set this rule for both signed and unsigned and never have a problem.
Setting up guidelines or rules in removing the signature in Outlook 2007. How to Remove a digital signature applied to all email messages in Outlook?
SIMPLE STEPS
1) Click tools you will see trust center under, Click this.
A Dialog box will appear
2) Click email security
3) Uncheck add digital signature outgoing messages
4. Click OK
