How to set screen resolution in bat file
20 points
Posted on - 09/24/2013
I am using Windows XP, I need about how to set screen resolution in bat file, so that when we run the bat file, the resolution of the screen will automatically get changed as per the codings in bat file, also do the needful for getting me the bat file coding for setting the screen resolution.
