How to set SysFader: iexplore.exe – Application Error?
I am receiving “SysFader: iexplore.exe – Application Error”. Whatare the causes for follow omission messages?How to set SysFader: iexplore.exe – Application Error?
The instruction at “0x64761480” referenced memory at “0x64761480”. The memory could not be “read”.
Click on OK to terminate the program
Click on CANCEL to debug the program
Answered By 10 points N/A #150379
Hello My Dear Friend,
This error can occur if you have very low virtual memory, so you need to increase your virtual memory. You can increase virtual memory by following these steps.
First of all, right click on the “My Computer” icon, go to “Properties,” then the “Advanced” tab, and click on Settings under Performance.
The second step will be to click on “Advanced“ tab in the Performance option, and then click on the Change button under Virtual memory.
Still another way to help you to get rid of this problem: You need to put your computer to a clean boot, safe mode, and follow the instruction in this article. After that put your computer back to normal mode.
Also check this website to help you resolve this issue.
