Hi techyv,
How to set the theme desktop win 7 1600 x 900? Can we set a size for the desktop theme for our operating system? I am not use to change the background or theme of my windows 7 computer desktop. But I realized that I have to learn from it.
Hoping for your help. Thanks.
You Can set your theme desktop win 7 1600 x 900 if your monitor supports that. Follow the steps to do it:
1. In the desktop click once in the right button of mouse and select "screen resolution"
2. click "detect" to detect your max resolution
3. Now click the "resolution" field and set it "1600 x 900" or max for full resolution.
4. Now click "apply" for save the changes
5. click "ok" to finish the job done.
Hi Greqory,
Yes, you can set your desktop resolution to 1600×900 only if your monitor that is connected supports that. I'll show you how to change the resolution step by step. Just follow the instructions below:
1)Click on "start"
2)Click on "Control Panel"
3)Appearance and Personalization
4)Display>Adjust screen Resolution
5)Change the resolution to 1600×900
6)Click on apply and wait for your screen to adjust
