Hi guys,
How to set the time in htc clock Samsung wave? I got those clock in my widgets and it seems like I don’t know how to set the time properly. I am not familiar with this bada operating system in Samsung wave mobile phone. Please guide me on the set up.
Expecting some help, thank you.
How to set the time in htc clock samsung wave?
Hi i think you've got the Automatically adjust time option enabled. So first and foremost by going to the settings tab disable that option. Then changed the time and the zone and then if you want you can enable that option back again ..switch off the phone and start again if required..thanks!
Hello Medison,
I am also using Samsung wave with BADA OS. You can change time and date with Date & Time option inside setting.
Then htc clock automatically detect the device time.
Another way, First of all find User manual of your phone, then searching for changing Date and Time.
You can download user manual of Samsung wave from the mentioned link:
https://www.scribd.com/document/34683022/Samsung-Wave-User-Guide
I wish this tutorial may be fruitful. Thanks!
Fenster Maxine
