How to set up voice interactive call for nokia c3?
How to set up voice interactive call for Nokia c3? I want to set a call forwarding or voicemail for my Nokia c3 mobile phone device, is the call forwarding feature available with c3 Nokia mobile phone? I need to set it up as soon as possible to direct some call to an important person.
Trevor John.
Best Answer by Vaishnav Simmons
Answered By 10 points N/A #187109
First make sure your service provider provides this facility and then you will be able to set the call forward. If you have the mobile phone manual then you can take guidance from there to set call forward or go to settings and then to call settings and you will be able to set call forward.
Smith Thompson
Answered By 5 points N/A #187108
Hi Trevor,
Yes, call forwarding or voicemail feature is available in Nokia c3.
Try to Press and hold 1 ( on your home screen ).
And to SAVE it, go to MENU, choose MESSAGING, then, VOICE MESSAGES and VOICE MAILBOX NUM. Enter your VOICE MAILBOX NUMBER and click OK.
For any question or info, you can ask your service provider.
Hope it will help you.
