How to set up win 7 time background
I would like to set up win7 time background to have desktop wallpapers changed in my preferred time (it changes once a day at 8 am now).
Is it default time or is there any method to change it?
Hello Joan,
It depends on your operating system. If it is windows 7 starter edition you have limitation on setting up your desktop wallpapers. But for the rest, these are the steps how to change the time interval.
1. Right click on your desktop.
2. Choose personalize.
3. Click background on the bottom of the window.
4. Click browse, and browse the folder of your backgrounds.
5. Click select all button at the right. a
6. Then at the bottom check the shuffle checkbox.
7. In the dropdown menu you can choose from 10 seconds to 1 day interval.
8. Click save changes.
Your desktop wall papers should change according to the interval you set.
Notifications
