How to setup and configure an IP Camera Network?
I want to know how to set up and configure an IP camera network with step-by-step instructions. I will be using it for my business and will place it inside my office. Please help me.
I am helping you to research in the internet. It’s a long process to set-up your ip camera. I suggest you to go this site http://ww38.ipcamerasupplier.com/blog/how-to-set-up-an-ip-camera-step-by-step.html. This will give you detailed tutorials in installing ip camera. Hope it will help.Â
Hi
You wanted to learn how to set up an IP camera for networked places. This is not a very big deal to learn. You can watch this video tutorial and also visit this webpage to learn that.
You can also read this pdf book for the purpose.
Hope these shall help you.
When you say Network IP Camera, it needs IP Address that is link to your network. Maybe it’s from your router or switch. And a computer is also connected from where the IP camera is connected so that you may what is playing on the camera.
First things you need to do, is to set the IP Address of the Camera if possible.
Second, connect your camera to the network from a router or switch using a Cat5 FastEthernet Cable and RJ45. Look on YouTube for the video on how to crimp the RJ-45 and the cable.
Third, connect the one end of the cable with RJ-45 to the camera and put the IP Address of the device into its network setting. And connect the other end of the cable with RJ-45 to the switch or router.
