How to setup and run Avast Netbook Edition?
Hi Experts,
I want someone who knows avast netbook edition.I am using avast on my desktop but need to upgrade it to netbook edition.I want to know this will affect my software applications authentication.Will they get blocked?Using high security like this suitable for me?Thanks.
Jabes Zion
Answered By 0 points N/A #132553
Avast is a very good anti virus software. Upgrading to the netbook edition will not affect your software applications authentication. They will not get blocked. You get the added features of the netbook edition which are very useful. In order to protect your data it is recommended that you use the highest security possible. So go ahead and upgrade your software. Just make sure you check the system specifications required and don't forget to restart your computer after upgrading.
