Hello Good Morning folks, How about lending a hand for a newbie here. My question is about the Ccleaner automatic update. How do you set it to download new update for the Ccleaner, does it update daily or anytime when there is a new update please explain & ways to set it up
How to Setup the Ccleaner automatic update?
Hello there Mathew,
You can have your problem solved by downloading some third application programs that will access your CCleaner or you can do it by CCLeaner itself. All you need to do is make sure that your CClearner checks for updates every x days so if there are any releases it will automatically download and install it. Hope this works.
Waall Mike
Hi Mathew,
CCleaner same as with all software has a setting to check updates automatically just make sure that you put a check on Automatic update on the Options icon then Settings. It checks for updates every 10 days.
OR
You can force CCleaner to update if you want to, you just need to create a batch file to do that just open a notepad then type in “ccleaner.exe/update” without the quotes, then save the name to update having a .reg extension.
