rchandra
40 points
Posted on - 04/18/2013
Can you please guide me to setup eclipse virtual editor? All your suggestions accepted.
How to setup eclipse virtual editor?
Hi there Rchandra,
Eclipse is a quite complicated tool and the best way to learn how to set it up and use it is via step by step videos.
I would like to suggest you to visit the following link:
www.eclipse.org/resources. On the given link you will find a video demonstration of how to install and use the Eclipse Visual Editor, explained in simple words followed by a screencam video that will show you every click that should be done in order to make things work.
Best regards,
Drake Vivian
Hi Rchandra,
In computer programming, Eclipse is a multi-language software development environment a base workspace and an extensible plug-in system for customizing the environment.
With regards to your query, you can download the latest VE build from ehecht.com and unzip into the eclipse folder (Eclipse 3.3) or into the new dropins/folder (Eclipse 3.4).
