How to setup email on Sony Xperia P?
Asked By 7060 points N/A Posted on -
How do I setup my tiscali email account on my Xperia P?
It will not do it automatically and even when i do it manually it doesn't work.
Best Answer by Stephanie Clar
Answered By 0 points N/A #83577
Set up Google email account
  • From the house screen, press Menu.
  • Tap Settings & on-line service accounts in Google.
  • Follow the directions provided if you wish to line up a replacement Google account, or simply enter your Google username and password to sign up using an existing account.
  • Your phone can currently be able to use with all Google services.
  • Set up POP3/IMAP email
  • From the house screen, faucet the applications bar
  • Select Email and then next.
  • Enter your email address and password within the given box. Go to next.
  • If the phone cannot download your email account settings automatically, faucet Edit details & Manual setup and enter the account settings one by one. Tap Next.
  • Enter an account name and also the name you would like displayed on outgoing messages. Click Done.
  • Your email account ought to be able to send and receive emails.
If you are employing a POP3 email account in your email application on your laptop,
you'll conjointly set it up on your phone.
Follow these directions to line up your phone for POP3 email.
Please note:
Please note that these directions are based mostly on a POP3 email account. If you've got a web-based email account, like Hotmail, Yahoo! Mail or Gmail, you wish to use the settings for web-based email.
Click here for info on the way to the established your phone for web-based email.
1. notice "Access purpose Names"
    Press the menu icon.
    Press Settings.
    Press Wireless & networks.
    Press Mobile networks.
    Press Access purpose Names.
2. produce new information affiliation
    Press the Menu key.
    Press New APN.
3. Enter information affiliation name
    Press Name.
    Key in Vodafone Mail and press OK.
4. Enter APN
    Press APN.
    Key in live.vodafone.com and press OK.
5. Enter country code
    Press MCC.
    Key in 272 and press OK.
6. Enter network code
    Press MNC.
    Key in 01 and press OK.
7. choose authentication sort
    Press Authentication sort.
    Press PAP.
8. choose APN sort
    Press APN sort.
    Key in default and press OK.
9. Save and activate information affiliation
    Press the Menu key.
    Press Save.
    Press the sphere next to Vodafone Mail to activate the info affiliation.
    When the sphere is marked, the info affiliation is activated.
    Press the house key to come back to standby mode.
10. Notice "Email"
    Press Email.
11. produce new email account
    Press alternative email account.
12. Enter email address
     Key in your email address.
13. Enter password
    Press Password and key within the password for your email account at your email supplier.
    Press Next.
14. choose server sort
    Press POP3.
15. Enter username
    Key within the username for your email account.
16. Enter incoming server
    Press the sphere below POP3 server and key within the name of your email provider's incoming email server.
17. Enter incoming port
    Press the sphere below Port and key in a hundred and ten
18. close up SSL encryption of incoming email messages
    Press the drop down list below Security sort.
    Press None.
19. choose setting for deleting email messages from server
    Press the drop down list below Delete email from server.
    Press the specified setting.
    Press Next.
20. Enter outgoing server
    Press the sphere below SMTP server and key in mail.vodafone.ie
21. Enter outgoing port
    Press the sphere below Port and key in twenty five
22. close up encryption of outgoing email messages
    Press None.
23. close up SMTP authentication
    Click need sign-in to show off SMTP authentication.
    When the box is next to the menu then item is empty, SMTP authentication is turned off.
    Press Next.
24. choose setting for retrieving new email messages
    Click the drop down list arrow below in Inbox check frequency.
    Press Manual or the specified amount.
25. choose default email account
    Click the Send email from this account by default just to pick a default email account.
    When the box next to the menu item is ticked (V), the perform is turned on.
26. flip email message notification on or off
    Press Notify me when email arrives to show the perform on or off.
    Press Next.
27. Enter email account name
    Key in an exceedingly name for the e-mail account.
28. Enter sender name
     Press the sphere below Your name (displayed on outgoing messages) and key within the needed sender name.
29. Retrieve email messages
     Press Done.
     Wait whereas your phone retrieves new email messages.
30. Exit
Answered By 10 points N/A #83578
The following is a guide that will help you set up an email account on your Xperia.
  • First you will need to tap the Home icon, and then tap the Grid icon so you can view all installed applications
  • After that tap the Email icon, and then enter your Email Address and Password for the account you are setting up and tap Next.
  • You will then choose the type of account: POP3, IMAP, Microsoft Exchange ActiveSync; select either POP3 or IMAP, as appropriate.
  • And then you will enter the Incoming server settings: Username, Password, POP3 server, Port, Security type, and Delete email from server, and after that tapDone, and then Next
  • Next toy will enter the Outgoing server settings: SMTP server, Port, Security type, Require sign-in, Username, and Password, and then tapDone, and then Next
  • After that you can go ahead and choose Account options: Email checking frequency, Send email from this account by default, and Notify me when email arrives and then tap Next.
  • That's it.
Carl
