althea heap
Posted on - 04/01/2013
Hello Techyv Users and Experts,
I need help in setup Geo proxy on My Windows XP PC. Please provide Few how to and download links to good Geo proxy software to setup on XP and their feature explained. I need help very urgently. I will appreciate quick response. Thanks in Advance.
How to setup geo proxy on Windows XP
HI Althea Heap,
I am happy to see that you want to use Geo proxy on your Windows XP PC as a server, that's a good idea. For this you want some useful link where you can download Geo proxy as well as installation tutorial. Now I am going to show something.
After starting GeoServer login to the web admin interface.
Click the Authentication link.
Under authentication filters panel and click the Add new link.
Click the HTTP Header link.
Fill in the fields of the settings form as follows:
Set Name to “proxy”.
Set Request header attributes to “sdf09rt2s”.
Set Role source to “User group service”.
Set the name of the user group service to “default”.
Save.
Back on the authentication page scroll down to the Filter Chains panel.
Select “Default” from the Request type drop down.
Unselect the basic filter and select the proxy filter. Position the proxy filter before then.
Following links may help you:
Configuration: http://docs.geoserver.org/2.2.5/user/security/tutorials/httpheaderproxy/index.html
User Guide: http://geoext.org/tutorials/remote-features-tutorial.html
Download http://geoext.org/downloads.html
Thanks for asking.
