How to setup mini acer wifi location?
How to setup mini Acer WiFi location? I have this mini Acer and seems like there is a problem with its WiFi location I want to setup this properly but how will I do that I don’t even know all the setting and location of each application. To all experts, can you give me the best solution for this problem to avoid wireless connection problem.
Best Answer by Asif120142
Answered By 0 points N/A #165326
You have to do this instructions given below:
  1. Move the WiFi switch to "on" position. Note all models have this switch.
  2. Open the windows start menu and select "connect to". A list of available connections will appear.
  3. Select all from the drop down menu to view all available networks within the range.
  4. Select the desired network and click "connect". Enter the security password and select connect.
Answered By 40 points N/A #165327
Hi Christie,
It is very simple to setup your wifi connection. You have  first Turn on the wifi, then
Go to Control Panel -> Network and Internet ->Manage Wireless Network.
Here you will see the list of all networks. Select the wifi network and connect.
It will ask you for password, so enter the password and thats it. You are connected.
Hope it helps.
