Good day guys,
How to setup Yahoo Mails on desktop login screen? I have some technical problem with my desktop it cannot make any screen sharing or viewing software. I thought this has to do with the difficulties on my yahoo log in screen on desktop. In my workplace my contractors really need yahoo mail for sending hundreds of emails daily and it would be easier for them to just simply logged on to the desktop screen. Is there a way to make this possible? If you have some idea I hope you would love to share it with us.
Thanks,
Well, Its is not a hard task. There are two ways you can do this.
1) Right click anywhere on the empty area of desktop > New > Create Shortcut > in Type location of the item as 'https://login.yahoo.com/config/login_verify2?.intl=us&.src=ym&.done=https%3a%2f%2fcompose.mail.yahoo.com%2f' > Click Next > Give a name to short cut > Click Ok. Done. If you want to avoid logging in every time, Check the "keep me signed in" option.
2) Open your yahoomail > minimize the window so that you can see both desktop and the mail box > select the address in the address bar > drag it on to the desktop. Done. Cheers.
Hi Joseph
Yes there is not just placing the Yahoo mail on the desktop screen but automatically log your account in.
To set up your yahoo on your desktop, click Start, Computer, click C:, program files, yahoo, then messenger, right click yahoo messenger.exe and click create shortcut to desktop.
Now to automatically log you in when you start your computer click start, run, type in the box msconfig, click start up locate yahoo messenger and check it.
