How to share a file in network
This is simple thing if you know about the windows basics. I am going to answer you with a assumption. That is you are using windows 7.
Ok. First connect to the network and select the file need to be shared. The right click on the particular file and you can see there is a sub menu called “Share with” All the network you have joined and save will be list on it and you can select the network and then follow the simple instruction you have.
If you need to share a folder, the procedure is also same. The difference is there are two places share. First one is the one I have already mentioned. Second one is you can select the properties from the menu you got from right clicking and there is tab called share and you can go to that tab. Then you can see a button called “share” click it and select the network you need to share the folder.
Alternatively, if the Network tab is not enabled, make required settings in the Sharing tab to configure the equivalent sharing. Choose "Share this folder" to enable sharing.
https://www.lifewire.com/how-to-share-files-in-windows-xp-818249
Notifications
