How to share mail folder on 4.0 ice cream sandwich?
I have 3 email accounts created on Social Hub, how can I view sent folder while running ICS 4.0.3 on Samsung Galaxy S2?
Before, when I used Gingerbeard 2.3.6, it was pretty simple to move the other mail folder as well. But now there seems to be no such option.
Is there any way to see other mail folder like send items/ draft / myfolder?
Answered By 0 points N/A #175160
Hi, Angela King Its not the android because its only an interface. What you are trying to say is the resent upgrade on the app itself.  Has been upgraded most of the Google up has been upgrade. It has a lot of major changes. The folders are not available any more there is a search bar so you can find what you’re looking for in a jeppy. Also in order that your important file will not be deleting you have to Flag them by clicking on the left corner. It yellow hers the link to guide you in the new HERE
