What is the best to way clean your monitors? Can I just use water or wiping them dry is okay?
How Should I Clean My Monitors And Screen?
No, never wipe it dry. It may cause tiny scratches to appear on the screen. This eventually will increase if you happen to keep doing it. The best way is using an ALL purpose screen cleaner. They can easily be found anywhere and are very easy to use. Just spray some of it on the screen and wipe with a clean cloth. Cleaning your screen daily will keep it shiny and bright and will also increase its life. You can use this similarly to clean your phone or laptop’s screen. Items with a glass body can also be cleaned. While cleaning, remember to wipe in a motion of ‘S’ so that it doesn’t leave wiping marks on the screen.
