Jose V Lau
20 points
Posted on - 08/02/2013
Hello TechyV support. I have purchased a Samsung Galaxy S3, and I want to install yahoo messenger on it so I can chat with my friends easier.
Can you please tell me exactly how to download and how to I install it?
I am pretty new so please be concrete.
How should I download the yahoo messenger on my Samsung Galaxy S3?
Hello Jose!
To install Yahoo Messenger you must follow some easy steps. First, be sure that your phone is connected to a wireless network or your 3G data (System Settings > WiFi or Mobile Networks). Then look through the applications you have already installed on the phone and find the Google Play Store App, because that's where you're going to download the application from.
Open the application and look for a small button that looks like a magnifying glass, usually found on the upper right corner. Tap on it and a small search bar will appear. Using the keypad, write "yahoo messenger" in it and then press search.
From the list of instant messaging application that appears, choose the one from the original developer, because it's the safest one. It reads under its name the Yahoo! Inc developer name. Tap on it, and it will open in a new window. Then all you have to do is tap on the Download button, and it will install by itself.
When you want to use it, look for it in the applications menu and open it in the normal way.
Then all you have to do is to enter your Yahoo! id and password and you're ready to go.
Good luck!
