How Should I Fix Windows Live Mail Error Id 0x800ccc0d
What are windows live mail error and what do windows live mail error ox800ccc0d mean? What are the steps to fix windows live mail error id 0x800ccc0d?
WLM is a mailing system. You can send and receive an email with windows live mail. It is provided by an internet service provider which will help in sync data between your email and your windows live mail. Error 0x800ccc0d means that the host cannot be found; it is unable to connect to the host server, i.e., ISP. Any credentials such as name or protocol if entered incorrectly can also cause this error.
To get rid of this error, you need to first check all your credentials if they are correct or not for that open your windows live mail and go to accounts, go to properties and select server tab. Confirm all the details you have listed and if any changed to make it. Any name or protocol name must now have spaces in it or any spelling mistakes.
Another way of resolving this error is to disable your email scanning from antivirus and to allow WLM firewall access.
