How to Show App Disk Space iPad Size to my client?
One of my client is asking to show app disk space iPad size,
Please help me to know the way around it.
Hi Volvo,
You will just need to do the following:
After that you will have to determine how much disk space each one uses, and then you will either right click on the programs or left click on them and do the following:
Click Command+i if you are using Mac
Click Control+I if you are using Windows
Or you can navigate to the File menu and then choose Get Info.
Carl
If you have an Apple iPad and you want to know the available storage space on the device, here’s how to check. To check the available storage space on your iOS device, on your device, go to “Settings”, “General” then “About”. In the “About” screen, scroll down and look for “Available”. The amount listed next to it is the device’s available storage space.
The amount listed next to “Capacity” is the total storage capacity of your iOS device. The “About” screen also lists the different media types stored on your device like songs or music files, videos, photos, and applications. As you store more and more files on your device, the amount listed in “Available” will also decrease.
