How to show desktop clock on the screen?
I have windows 7 Ultimate 64 bit installed and was wondering if someone knows if someone knows how to show desktop clock on the screen.
Any kind of help would be appreciated.
Hi Matland, just right click to your desktop, then select "Gadgets"
A pop up window will appear
There is a analog clock as you see
Double click the clock , it will show to your desktop
That's it…
Matland maud
Good Day!
Firstly go according to my direction:
Start > control panel > Clock, Language and region>Add the clock gadget to the desktop > then double click on the clock then you will get your expected clock to watch time always.
Edit time and date
1. by changing time zone
2. Change location
Good Luck.
Hi Matland,
That is built in feature in windows 7. Very easy to do this using windows gadgets. For activate this,
Right click empty area of desktop > Click gadgets
You can find clock gadget on there. Just drag and drop to desktop.
If you can’t see clock in there, you can download from internet.
Good Luck.
Hi, You just need to Go to Windows Desktop and open Context Menu.
RIGHT CLICK on the Desktop and then Select GADGETS from the list and then another window will be opened will all gadgets that are Available on the system.
Just Simply Drag the CLOCK gadget anywhere on the desktop and then close the gadgets window.
That’s it!
