How to show image of toolbar on Google any browser
I need to know about how to show image of toolbar on google. I use variety of browsers of if there is any plugin then tell me irrespective of its compatibility.
Depending on the browser you are using, below are instructions on how to show image of toolbar on google.
For Internet explorer:
Go to the Tools button > Manage add-ons> Enable / Disable Add-ons.
A Manage Add-ons window pops up. In the window, get the Google Toolbar entry and the status click on the status once if it says Disabled and then on Enable in Settings. Finish by clicking OK. .
For Firefox:
Go to the View menu> Options> Toolbar. If it is not there, go to Add-ons or Ctrl + Shift + A
Look for any error messages in the list of Add-ons that appear and see if there is a new version by clicking on the Find updates button. This is because some add-ons are not compatible with updates to Firefox.
HI,
Amber ward
Different browser have different steps to view the toolbar , here is the solution
Google chrome
go to settings >> extensions >> turn on developer mood >> download Add-ons >> enable
Firefox
Go to the View menu> Options> Toolbar. There is Add-ons enables / disables button .
You can use easily.
Thank you.
Notifications
