How to shuffle pictures using code in vb
Does anyone have any idea to shuffle pictures using code in VB? I need to know it quickly. Please help me out.
There kimghartwick to achieve that kind of task in VB all you need is a box, your pictures and a timer. I have uploaded my code for you about this matter, you can just copy and paste the code read it so you can see what it does. This is very helpful in presenting your image into your program.
And this code can help your program to have some good impact to the audience.
So if you really need this code. Heres the link vb code.
Code shown in below link will use a string array to perform the shuffle operation. To test the code add some string characters to your array and call the Shuffle array method passing the String array as a parameter.
Then the method will get the characters and change their order dynamically. Finally totally different character array will be served to a as a result.
