How to simulation of anti virus with java code?
Hi guys,
I want to design an anti-virus program by myself by java. But I don’t know where to start. Please give me a systematic tutorial how to simulation of anti virus with java code.
Thanks
Hi guys,
Thanks
At this time, i think it is not possible to create an antivirus using java code because anti virus needs to be touch in core of the OS, How possibly this can happen for a java code. Maybe you should try for another project. This project is not as easy as you think because there is a lot to consider.
Hi Nadia,
Antivirus program in Java is although not recommended to be a Frontline anti-virus program however I would you to go through following you tube tutorial which would guide you through the appropriate steps and programming objects. This tutorial would give a basic glimpse of the outline structure of an anti – virus program rather than rigorous Java source code.
Hope this helps.
Thanks
