How so I disable winzip outlook companion?
I have installed a WinZip Companion in Outlook.
Ever since installing it, my system has slowed down, Winzip could not compress files and Outlook crashes.
How do I disable Winzip Outlook Companion?
I'm using Microsoft Outlook 2010 and WinZip Companion 2.0.
Best Answer by oliverpowell
Answered By 50 points N/A #183240
Try to Uninstall WinZip Companion Outlook
1. Go to Start – All Programs – WinZip Companion Outlook.
2. Click Uninstall and then follow the Wizard to uninstall the program.
3. Click Yes to confirm that you want to remove it.
4. When the removal is complete, click "Finish", and restart your computer.
Uninstall WinZip Companion Outlook with Windows Add/Remove Program
1. Click Start menu – go to Control Panel – double-click Add or Remove Programs.
2. Highlight the program and select uninstall to remove it
3. Click Yes and confirm.
Answered By 10 points N/A #183241
You can remove WinZip Companion in Outlook by following a few simple steps.
1. Go to Control Panel. If you are using Windows 2000, that would be in settings.
2.Open Add or Remove Programs.
3. Just find the WinZip E-Email Companion entry in the list of programs and click Remove.
Once you have completed this process, all the Companion functionality and tools will be deleted from Outlook.
Hope this helps you speed up your system!
