Hello, Computer experts!
I recently encountered a problem in Adobe Photoshop. It has a delay when launching the application.
When I double click on the icon, the program runs for awhile then an error would appear that says it could not allow the request to be completed.
Please help me to know more about this error.
Please include solution to repair this error.Â
Adobe Photoshop
Could not complete your request because of a program error.
seotechv
How to solve Adobe Photoshop Program Error
Did you install some plugins or something before it happens? if you did just uninstall those and hope it works again. By the way what OS are you using? 32/64 bit? and also if you don't care about the previous settings of your PS example your saved brush/texture settings just uninstall your whole Photoshop higher chance of it to be fixed…
Hi Eckel Andrea
Well in my opinion I think the main problem with your adobe Photoshop is the font uploading problem.
I have noticed that in Photoshop when you are not using proper fonts loaded for a particular file it’ll give you an error.
When you’ll load fonts into your Photoshop then your problem will surely resolved.
Try to use suitcase for your font management.
Because maybe you’ll not consider which font is considering problem.
Upload full suitcase for all available fonts and voila, your problem is solved.
I hope so this will help you.Â
Johnstoon Leen
