How to solve the downloading error ?
Asked By 460 points N/A Posted on -
I don't know has anybody ever experienced this problem or not, but I am unable to save iTunes onto my laptop. I have downloaded it at least 5 minutes ago. When the downloader asked me to save the software,
I saved it on the desktop. But on desktop, I found nothing. Then I thought may be I made any mistake. Then I downloaded the software again and I saved it on the desktop. But, this time I realized the weird problem. Without ITunes I am unable to set up my ipod nano which I brought someday ago. I tried to find out the ITunes in my whole hard disk whit search option, but it gone to vain.
Any body, please help me in this case. I use windows vista (If it is need to you)
Thank you
Best Answer by seangel
Answered By 0 points N/A #92162
Before you download iTunes on your laptop, you need to clean first your Internet Browser history, temporary internet files and cookies.
Try this one…
In your Internet Browser click the TOOLS, click the INTERNET OPTIONS, then click DELETE. You have to make sure that the temporary internet files, cookies and history boxes are all checked and then click the DELETE. After that, you can now download the iTunes.
Hope your problem will be solved.
Answered By 0 points N/A #92164
If you face any problem when download any file using Mozilla Firefox.
clear download history can fixed your problem.
1. Click "tools" from menu bar.
2. Then click "download" submenu and click "clear all" from download window.
You can choose different download folder.
1. At the top of the Firefox window, click on the Firefox button (Tools menu in Windows XP) and then click Options
2. Select General panel (Main panel in Firefox 3.5).
3. In the Downloads section, select Save files to.
4. To select a download location, click Browse…. Choose a different folder to try saving files.
5. Click OK to close the Options window
Thanks
Ripon zaman
