How to solve an error associated with Network sharing device
This is driving me crazy, I always get an error message,suspected Network sharing device for the first time, whenever I try to load the VPN, what could be wrong?
Best Answer by Maybt Barton
Answered By 0 points N/A #142016
Hello Araceliariana.
May be the problem is in your network sharing setting.Try this way:
1.Click on the internet access button.
2.Open network and sharing center.
3.Open the advanced setting there.
4.You will get a network discovery and protection option.Turn these option off.Your problem will not occur again.
Thank you for your question.
Answered By 0 points N/A #142017
Good day!
Let me explain to you why this kind of error occur, the IP address that are trying to connect on your network is an proxy server and the error occurs when the proxy alters your computer's request or there's a delay on the server's response.
to fix this, here are some steps you should follow :
A. Click start button.
B. Locate and click Control panel.
C. Locate and click Network and Internet ( View by : Category) then Network and Sharing.
   C.a Network and Sharing (View by : Small Icons / Large Icons)
D. Locate and click Network and Sharing center.
E. Locate and click Change Advanced Sharing Settings.
F. Scroll down and click Public for it has more options to show.
G. Locate Network Discovery then Choose Turn off network discovery.
H. Click Save Changes.
Hope I Have helped you!
Take Care!
