gyle kugler
90 points
Posted on - 02/24/2013
I use Pgi visual fortran 2008 in Windows OS to create a project that consists of a fortran library.
It compiles and builds ok but when I set a link , I get some errors .
I have changed the platform such as eclipse , but the problem remains the same .
How can I fix it ?
How to solve error problem on Pgi visual fortran 2008 ?
Hello
You forgot to mention what kind of error you get, we can't help you if don't provide us with enough information. If your error keeps popping on every platform then obvious it's your error. Try to copy text of your error and google solution for it. There is no other we can help you on this. Regards.
I've learned that your having problem in Pgi visual Fortran 2008 in Windows OS. Please Note this: PVF is incompatible to visual studio express it will not successfully run/install in the system with VS express regardless of the PVF Version or on a VS express version. So to resolve your worries kindly choose which version is best compatible with your windows OS.
Learn them on this website: www. pgroup.com
Hope this will help you resolve the issue.
Thomas
Hi guys, thank you for your wonderful remedy!
I was so anxious about my problem that I forgot to mention my error message. Thomas C.
Saucedo, your suggestion was super, because I was able to fix my problem by following your suggestions. Actually, I didn't know that PVF is incompatible with Visual Studio Express.
You recommended that to solve this problem, I need a version which is suitable for my Windows OS.
I have done this, and as a result I am now free of this kind of error.
Thanks again, my friend, for assisting me.
