How to solve hanged problem?
For last few weeks I am in a great problem. My computer gets hanged often whenever I run two or more than two application at once. I am tired of restarting the computer manually. Is it caused by virus or hardware? How can I solve this?
Thank you
Best Answer by Lili Dean
Answered By 0 points N/A #103557
Hi Hannah,
It might be caused by malware, so try to check if your PC does not have any malware.
Another reason might be your hard drive memory. So, check the space and try to delete recycle bin and to clear your hard drive. Even you can try to extend your hard drive memory (on the webpage of the manufacturer).
Kind Regards,
Lili
Answered By 5 points N/A #103558
Computer gets too slower when there are not enough memory running in you system. You could probably upgrade your system memory that can be dump sooner. It will be worst if you will not replaced it either. Check the compatibility and usage off all start up programs to manage this. If you are aware of this start up programs.
I prefer to clear it up to lessen the memory load.
Hope it helps.
Dlanear
