How to solve Internet Explorer Script Error?
How to solve Internet Explorer Script Error? After startup my Windows XP I found following error:
An error has occurred in the script on this page. It’s possible to fix the problem?
Richard Miller
Richard Miller
Well to enable the scripts on your Internet Explorer you have to customize the settings of internet security of your Internet Explorer. To do so you have to follow this procedure:
Hope this will be good for you.
Have a nice day Richard!
I don't usually pay attention to Internet Explorer Script Error when it pop-up but during these past days, I start getting annoyed by this. I said, Enough is enough and it's time to get rid of this. I just simply do these steps, follow the instructions below;
* Open Internet Explorer, click on Tools.
* Then Internet Options and Advanced tab.
* Look for the "Disabled script debugging" and put a check on it.
* Uncheck below it says "Display a notification about every script error".
Now, tell me if you still getting error message when browsing?
Try these steps;
* Open your Internet Explorer.
* Go to Tools, and click on Internet Options.
* In that page, click on on Security tab.
* Set it to Default Level.
* Click Ok and close the browser.
