How to solve my sound card problem ?
First you have to check for the hardware weather it is working properly and not. If your hardware is working correctly and not out of order. Then download the latest driver for the sound card and install it. Then check it will start working properly.
If not then you have to buy a new sound card for your and plug it into your computer and check. If this is working correctly on your computer. Then it means that your computer sound card was out of order. And that's it hope this will solve your problem.
The driver that you have mentioned is for an integrated sound card which means it is not on a separate PCB but is in the motherboard itself. If this is really the case, then you should be able to get the sound card drivers or the audio drivers from the motherboard manufacturer's drivers and downloads website.
If your operating system is able to detect the sound card and the driver installs correctly which should consequently mean that there won't be any errors or bangs in the Device Manager referring to the audio device.
If you still don't hear any sound, make sure your speakers are connected to your computer properly and that the cables that you use to connect the speakers are also working. See to it that your audio is not Muted and your speakers have power.
Hi Jkdas
There are many ways you can fix this issue. Pay a visit another Techyv post to get more new techniques to resolve this problem.Â
