I am facing problem in ICQ protocol for TCL developers in displaying the buddy list. How can I add protocol icons in the buddy list? It is not showing the conversation Windows. What will be the solution? Please help me anyone. Advance thanks.
How to solve the problem in Icq protocol for tcl developers?
Justine,
You can use two ways to add protocol icons in the buddy list. This is how you do it . Besides the status selector at the bottom of the Buddy List window, there is an area that has a photo icon if it is not set, click that and select an icon from there. The icon will take effect for all accounts you have configured in Pidgin. The other way is by going to Account->your account->Edit Account.
On that dialog, check the box labelled "Use this buddy icon for this account:", then click the leftmost button below that checkbox. Select your buddy icon. Some protocols impose a maximum file size of the icon. If you experience problems, you could try resizing the icon yourself before setting it.
