How to solve this unicode to ascii convert vb6
Hello everybody. I have Unicode to ascii covert nv6. My problem is the following:
I have to write a xml file formatted according a specific xsd and dtd. I've created my xml file writing it with VB6 ( put #fn ,,bytearray of my file ). In particular the byte array contains only significant bytes without 0byte. But if I open it by ULTRAEDIT I see the file written with 2bytes/char ( starting with FF FE bytes ), and appears ( seeing it in hex editor ) like ÿþ<?.x.m.l. and so on where "." correspond to a 0byte in hex part. The difficulty is that the application ( 3rd part ) that must CHECK this XML discards it because of that code.
