janajacobb
Posted on - 10/27/2012
Hello experts,
How to solve unread picture problem?
I am using adobe Photoshop CS 5 in editing my pictures for my fine arts project.
And having this file error saying unable to read photo, what should I do to reveal the photo?
I need the picture to import in my adobe Photoshop CS 5 and edit the whole content as a subject for my editing skill.
I hope you can help me.
Hi Buddy,
Your problem might be the file of the image you have is unsupported in Adobe Photoshop cs5.
In order to import the image file, you have to know what its file format is. After knowing the format, open the image in paint.
After open the image in paint go to File > Save as. then, the window for saving will pop-up.
At the bottom above the Save button, there is the pane for Name and selection Save as type:
Go to Saveas type > JPEG. Then, click save.
The image that you have saved is now in JPEG format, and it is able to import using Adobe Photoshop cs5.
Hope it'll help.
