How to solve virtuemart router problems
Hello experts!!!!!!
I need help to solve virtuemart router.php problems. I have just upgraded a Virtuemart installation to VM 2.0.12. The problem is that after upgrading I have been getting a problem like this:
Notice: Undefined index: categories in /home/proequip/public_html/components/com_virtuemart/router.php on line 2059
I just don’t know what should I do? Can anybody help? Thanks in advance.
Answered By 0 points N/A #147161
From your description I come to know that you are facing a problem for using VM 2.0.12.After update you faced this problem.
I think you faced the problem for some technical problem. Update files don’t work properly may be for some technical problem.
In this stage you have to remove the previous software and re-install it. Now run the update.
You can update VM 2.0.10 from
Hope your problem will be solved soon.
Thanks
