Hi all,
In most times you cannot act anything with 0xc004f200 error message by yourself because generally it indicates that Microsoft blocked your key.
And Microsoft blocked your key by several reasons.
If you apply pirated CD-key also want to activate the key. So, please get an official copy of any edition of Windows 7.
If you have purchased blocked or pirated key. Immediately you want the repayment from vendor.
If you have applied your key with over 2 computers. Keep in mind, you have restrictions.
Error: Error 0xc004f200
Windows Activation
Activate Windows now
You must activate Windows within 19 days to continue using all Windows features.
Activate Windows online now
Ask me later
What is activation?
Read the privacy statement online
Cancel
How to solve Windows Activation Error 0xc004f200
Hello Beatrice,
When windows asks you to activate the operating system it is because of the following reasons:
The copy of windows you are using is not genuine.
You have not inserted the activation key on windows yet.
To solve that issue, you will need to do the following:
Make sure that you have installed a genuine copy of windows. If you used any generating tool to activate the operating system you may need to get a genuine copy of windows that has got an installation key.
If you installed the windows application but you did not insert the key, make sure that you obtain the key and insert for you cannot use the OS without first activating it.
Carl
I’m not sure if there’s a solution to this if you simply want to fix the error “0xc004f200” you receive during the activation process. Not unless you purchase a new operating system and a genuine one. You are getting this error because the operating system running on your computer is totally not genuine and in order to activate your platform with Microsoft, of course, they require that your product is certified genuine. Meaning, you bought your operating system from an online store maybe or from local software store and not just downloaded from any other website that offers it for free.
If this is the case then your operating system is really a pirated copy. When you install Microsoft Windows on your computer, any version starting from Windows XP onwards, the product only has several days to work and it needs to be activated online so that you can continue using it. Otherwise your operating system will suddenly not work after the said period has been exhausted. Earlier versions of Microsoft Windows don’t require online activation like Windows 95, Windows 98, Windows 98 SE, and Windows Millennium because it can be purchased in a licensed CD. So, to solve this you need to purchase a genuine Microsoft Windows operating system and then try activating it again.
Please follow these steps to repair 0xC004f063 error:-
This is a kind of error shown when your PC has registry error. Yes, this is a registry error occred on your OS.
1.Please download the error repair tool by searching it on web.
2. You can download any tool from trusted site and follow the steps shown on it.
3. Please de-select any unnecessary software that comes with installation and complete the download & setup there you are ready to repair.
The downloaded software will show you any errors, if there are any such errors click on repair all. Everything is fixed now.
