How to specify the download path folder on Firefox
Firefox downloads files automatically into "Download" folder.
Is there an option as to what folder I want my file to be downloaded, and work on it?
I don't want to change it forever from Firefox preferences.
I just want to specify the path before each download.
Answered By 0 points N/A #125358
Hi!
You can change or specify the download path before each download in Mozilla Firefox.
This is very easy job. For this, you just follow a few steps.
First open your Mozilla Firefox and then go to its tools menu on the top of Mozilla Firefox in the menu bar.
Then click on option tab.
A window will appear just like this:
In this window, you can see the download tab at the very first screen. From here, find this word “Save as to” and brows the location of that folder which you want to use as default Mozilla Firefox download folder.
If you want to use different download folder for different downloads, then you need to change this option manually.
