How to speed bing translator on my PC
Hello expert, I am using the software Bing translator to translate on online. But when translating it is very slow on my PC. Please can you give me details how to speed bing translator on my PC?
Hello there Kurtt,
The speed of Bing translator is based on your Internet connection so therefore, if your Bing translator responds very slow then your Internet connection is not fast enough to translate faster. If you want to speed up the performance of your Bing translator then you need to upgrade your Internet connection first.
Hope this helps you.
Regards, Roland.
Rather than using Bing translator, try using Google Translator, as its performance is great and time to translate a word, phrase, or sentence takes just seconds, and it is web based. So you won't need to install anything onyour system, and you don't need to worry about payments because the service is free.
