Hi guys,
I have windows PC which is XP 2000 and it is very very slow and I want to speed it up. So what should I do to speed my PC please guide me in detail what steps can I take to make my PC work normally and speed it up like before it was. Thanks in advance please do answer me.
points
How to speed up My PC? Please help
Speeding up your PC will need some files and registries to be deleted from your PC. Unnecessary files and registries slows down the system. Also, some tweaking to the system configuration is needed.
In order to do that, you need a tool called “Wise Care 365”. It’s a free and powerful tool to remove unnecessary items from your PC. After installing, run a scan and remove the unnecessary files.
There are also other paid version software that will do the job more efficiently. “System Mechanic” is also a good one, said to be the best.
Make sure that no unnecessary programs and features are installed on your system. If so, uninstall them. Find out the applications that you didn’t make any use of and uninstall them.
Updating your system driver is also necessary. Contact with the manufacturer’s website of your PC’s hardwares and download the latest driver from them. It’s quite important because newest drivers come with newest features that includes faster runtime.
If possible, upgrade your operating system. This might be a cause of your slow performance, too. Learn how to install Windows 8, 7, Vista and XP.
Hi
There are many ways to speed up your PC. Upgrade all of your hardware,delete some unnecessary programs and deleting your history to speed up your PC. For more visit this link : How to speed up my PC?
