I have a PC with the following specs:
CPU-Core 2 Duo 2.4GHz
GPU-Geforce 210 1GB
RAM-2GB DDR3
My PC is running slow from a few weeks though I haven't let any malware to attack my PC. I have not connected any external storage to my PC.
What should I do in order to speed up my PC overally? I have Windows 7 if that helps.
How To Speed Up A PC Overall?
Every operating system is designed to produce unwanted elements that will slow down any machine, no matter how highly it’s configured. You have to tweak your system in order to fix this issue.
Using any third-party software is strongly recommended because there are files that can be important but if deleted by mistake, it might crash your entire PC. So, any good and strong, popular PC tweaking tool is recommended.
CCleaner is one of the best and slimmest PC cleaner, able to speed up any PC twice or more. Get CCleaner.
Wise Care 365 is another awesome tool with super power to enhance your PC’s condition with tremendous power. Get Wise Care 365.
There are also other awesome tools like System Mechanic, WinOptimize etc.
Regularly clean your PC, defrag your HDD e.g. once in month to have a healthy, smooth PC.
